Best Answer Engine Optimization Tools for ChatGPT Worth Comparing
Your brand is missing from ChatGPT. What should you fix first? Compare the best optimization tools for audits, recommendations, technical improvements, content, and pricing.
See what ChatGPT thinks
Finding out that your business barely appears in ChatGPT can be surprisingly easy. Fixing the reasons behind it is a different problem. A visibility tracker might show that competitors appear more often. A rank tracker can reveal the prompts where they sit above you. Citation analysis can uncover the pages ChatGPT relies on. But eventually someone has to answer the practical question:
What should we change on our website or elsewhere online?
Different optimization tools approach that problem in different ways. Some audit your website for crawler and content problems. Others compare your pages with content already winning AI citations. Some turn visibility gaps into a prioritized checklist, while the more advanced platforms can rewrite pages, create content, push changes into a CMS, or support outreach to third-party sources.
This guide compares them specifically from that perspective.
What you’ll learn:
  • How ChatGPT optimization tools differ from visibility trackers.
  • Which platforms help move from AI-search gaps to practical fixes.
  • How the tools compare on audits, recommendations, execution, and pricing.
  • Which ChatGPT optimization tool best fits your website, team, and workflow.
ChatGPT optimization tools vs. AI visibility trackers
Before comparing products, it helps to separate two categories that are increasingly marketed under the same AEO or GEO label.
AI visibility tools tell you what is happening. They track signals such as brand mentions, visibility, answer positions, share of voice, competitors, citations, and sentiment.
Optimization tools help you decide what to change next. They can identify technical accessibility issues, weak or missing content, competitor gaps, and third-party sources that may influence AI answers. The stronger platforms also prioritize these opportunities so you know what deserves attention first.
In simple terms:
  • Visibility tools: measure where and how your brand appears.
  • Optimization tools: identify why performance may be weak and what to improve.
  • Platforms that combine both: let you find a gap, act on it, and then measure whether anything changed.
If your main goal is simply measuring presence, our guides to AI visibility tools, AI rank trackers, and AI brand mention trackers cover that side of the market in more depth.
Here, the standard is different: how useful is the tool once you already know there is a problem?
Best ChatGPT optimization tools compared
These platforms approach ChatGPT optimization in different ways, from technical audits and content recommendations to citation analysis and execution. Here’s how they compare.
ToolStarting priceMain optimization focusOptimization workflow Best for
Beamtrace$20/mo annuallySite-wide ChatGPT optimization across technical, content, visibility, competitor, and citation gaps Finds gaps → prioritizes Actions → guides fixes → measures results SMBs and teams that want a complete path from diagnosis to improvement
HubSpot AEO$45/mo annuallyContent, technical, citation, and outreach opportunitiesPrioritized recommendations with HubSpot execution optionsSmall marketing teams
Otterly.AI$25/moCrawlability and on-page GEO readinessGEO audits + recurring recommendationsBudget-conscious website owners
Semrush AI Visibility$99/mo/domain annuallyAI readiness, prompts, competitors, SEO/content gapsStrong research; execution through wider Semrush toolsExisting SEO teams
Writesonic$79/mo annuallyContent, technical issues, external mentionsContent creation + audits; deeper Action Center on higher tiersSEO/content teams
Profound$99/mo annuallyAEO content optimization and automationScore → diagnose → optimize → CMS workflowAdvanced content teams
Scrunch$250/moAI-agent accessibility, retrievability, and citabilityPage-level recommendations and optimizationLarger, technical websites
Pricing and plan features change frequently, so check each provider’s current terms before purchasing.
Best ChatGPT Optimization Tools for Businesses
These tools take different approaches to ChatGPT optimization, from technical audits and content recommendations to citation analysis and execution. Here’s how they compare for businesses.
1. Beamtrace
Beamtrace - the best optimization tool for ranking in ChatGPT
Built by the team behind Elfsight, Beamtrace brings the same practical, user-friendly approach to AI visibility and optimization.
Beamtrace analyzes your website together with its current AI visibility and turns the issues it finds into specific Actions. Instead of stopping at a visibility score, it helps identify what may need to change across technical setup, content, positioning, structure, and topic coverage.
Optimization is connected with Beamtrace’s wider tracking data, so competitor wins, weak rankings, missing citations, and other visibility gaps can help explain why an Action matters and what should be improved next.
Main Features
  • Website and ChatGPT optimization audit
  • Technical accessibility checks
  • Content and positioning analysis
  • Topic and information-gap detection
  • Prioritized Actions with impact and effort
  • Competitor and citation analysis
  • Implementation guidance
  • Visibility and ranking measurement after changes
👍 Best for💰 Pricing plans
SMBs, local businesses, and website owners that want a clear, prioritized list of what to improve without building a dedicated AEO team.14-day trial with no credit card
Paid plans start at $20/month billed annually
Key limitation:
Beamtrace is currently better suited to focused SMB and single-business workflows than large multi-site enterprise content operations.
2. HubSpot AEO
Hubspot AEO
HubSpot AEO combines AI visibility monitoring with prioritized recommendations. It analyzes prompts, competitors, citations, and other gaps, then suggests actions such as improving a page, creating new content, addressing a technical issue, or strengthening visibility on third-party websites.
For existing HubSpot customers, those recommendations can also connect with the wider content, CRM, social, and marketing workflow, making AEO part of the same system teams already use for customer acquisition.
Main Features:
  • ChatGPT and multi-engine visibility tracking
  • Prompt monitoring
  • Competitor analysis
  • Citation and source analysis
  • Prioritized AEO recommendations
  • Content-gap detection
  • Technical recommendations
  • Third-party outreach opportunities
  • Integration with HubSpot marketing tools
Marketing teams that want AI-search insights translated into practical content, technical, and promotion recommendations.Standalone HubSpot AEO starts at about $45/month billed annually
Broader execution features are available through HubSpot’s Marketing Hub plans
Key limitation:
The standalone AEO product is more recommendation-focused than execution-heavy. The deeper content and campaign workflow becomes more useful when combined with the wider HubSpot ecosystem.
3. Otterly.AI
Otterly.AI
Otterly.AI combines AI visibility tracking with a GEO Audit for individual webpages. Its optimization tools focus on whether AI crawlers can access a page and whether its content is structured clearly enough for AI systems to process.
The platform also connects these audits with prompt research, citations, and recurring recommendations, giving smaller teams a relatively inexpensive way to move beyond simple visibility monitoring.
Main Features:
  • GEO website audits
  • AI crawler accessibility checks
  • Robots.txt analysis
  • Content readiness checks
  • Prompt research
  • Citation analysis
  • AI visibility monitoring
  • Recurring optimization recommendations
  • Large-volume URL auditing
Small businesses, independent marketers, and website owners that want inexpensive GEO diagnostics alongside AI visibility tracking.Lite plan starts at about $25/month
Includes AI visibility tracking, GEO audits, and recurring recommendations
Key limitation:
Otterly primarily identifies opportunities and recommends improvements. Most content changes and technical fixes still need to be implemented manually outside the platform.
4. Semrush AI Visibility
Semrush combines AI-search research with the traditional SEO data many marketing teams already use. Its AI Visibility tools can uncover weak prompts, competitor advantages, citation patterns, content opportunities, and technical AI-readiness issues.
The main advantage is context. Teams can investigate a ChatGPT visibility problem alongside keywords, organic rankings, backlinks, technical SEO, competitors, and content performance rather than treating AI optimization as a completely separate discipline.
Main Features:
  • AI visibility analysis
  • Custom prompt tracking
  • Competitor benchmarking
  • Prompt research
  • AI-ready Site Audit
  • Keyword and topic research
  • Technical SEO analysis
  • Content optimization tools
  • Traditional SEO + AI-search data
SEO teams that want ChatGPT optimization to work alongside their existing keyword, technical SEO, competitor, and content research.AI Visibility starts at $99/month per domain billed annually
Wider SEO + AI functionality is available through larger Semrush packages
Key limitation:
The standalone AI Visibility product is strongest at research and diagnosis. Much of the actual optimization work happens through Semrush’s wider SEO and content toolset.
5. Writesonic
Writesonic
Writesonic combines AI visibility analysis with content, technical, and off-page optimization workflows. Its GEO Action Center can surface technical issues, missing content, citation opportunities, and third-party websites where competitors have stronger representation.
The platform is especially strong when an opportunity needs to become content. Teams can move from identifying a gap into generating, updating, and optimizing pages within the same broader SEO and GEO environment.
Main Features:
  • GEO Action Center
  • Technical issue detection
  • Content-gap analysis
  • AI content generation
  • Existing-page optimization
  • Citation opportunity research
  • External mention analysis
  • Competitor research
  • Website audits
  • Impact and effort prioritization
  • SEO + GEO workflows
SEO and content teams that want AI visibility, website auditing, content production, and GEO execution inside one larger platform.Paid plans start at about $79/month billed annually
Advanced Action Center functionality is available on higher tiers
Key limitation:
The complete optimization workflow is not available at the lowest price point. Some of the most useful Action Center capabilities require higher-tier or Enterprise access.
6. Profound
Profound
Profound combines answer-engine intelligence with a structured content optimization workflow. Pages can be benchmarked against content already earning AI citations, scored for AEO readiness, and analyzed for structural, topical, and technical weaknesses.
Its Agents extend that process into execution by helping teams rewrite, refresh, and produce content based on the findings. This creates a workflow that can move from AI-search evidence to an optimized page and eventually into a connected CMS.
Main Features:
  • AEO content scoring
  • Competitive content benchmarking
  • Structural and technical recommendations
  • Citation-based optimization
  • AI Agents
  • Content rewriting and generation
  • CMS-connected workflows
  • Prompt and competitor intelligence
  • AI visibility measurement
Advanced content teams, agencies, and larger organizations that want to optimize and scale content using AI-search and citation data.Starter: $99/month billed annually
Growth: $399/month billed annually
Enterprise: Custom pricing
Key limitation:
Profound’s strongest automation and multi-engine workflows are designed for more mature AEO programs and become considerably more expensive on higher plans.
7. Scrunch
Scrunch focuses heavily on what happens when AI agents interact with a website. Its diagnostics examine individual pages for retrievability, citability, technical blockers, and content problems rather than relying only on a domain-level visibility score.
For larger websites, Scrunch can go beyond diagnosis through its Agent Experience Platform, helping businesses control and optimize the content experience delivered to AI agents.
Main Features:
  • Page-level AI diagnostics
  • AI crawler accessibility analysis
  • Retrievability checks
  • Citability analysis
  • Technical blocker detection
  • Page-specific recommendations
  • Agent traffic monitoring
  • Citation monitoring
  • Page optimization
  • Enterprise Agent Experience Platform
Larger websites and technical teams where AI crawler access, page retrievability, citability, and agent experience are important optimization problems.Core starts at about $250/month
Enterprise Agent Experience Platform: Custom pricing
Key limitation:
Scrunch is more technical and enterprise-oriented than most small businesses need, while some of its most advanced agent-experience capabilities are reserved for Enterprise customers.
How to Improve Your ChatGPT Visibility
The best ChatGPT optimization tool depends on the problem you need to solve. Instead of comparing feature counts, identify the weakest part of your current presence and start there.
🛠️ Fix technical access before optimizing content
Make sure ChatGPT and other AI systems can properly reach and process the pages you want them to use.
Check:
  • Robots.txt
  • AI crawler access
  • Rendering
  • Broken URLs
  • Website architecture
  • Server and CDN settings
Beamtrace, Otterly, Semrush, Writesonic, and Scrunch all provide technical analysis, while Scrunch goes deeper into AI-agent accessibility and infrastructure.
Technical fixes do not guarantee a better ChatGPT ranking, but inaccessible or difficult-to-process pages can undermine everything else you optimize.
🧩 Make your business easier for AI to understand
Once access is working, review whether your website clearly explains what your business does, who it serves, and why it is relevant.
Prioritize:
  • Homepage positioning
  • Product and service descriptions
  • Use cases
  • FAQs and customer questions
  • Titles and headings
  • Content structure
Beamtrace and HubSpot are useful for identifying what should be added or improved, while Profound and Writesonic go further into generating and optimizing content.
For businesses looking for the best ChatGPT SEO tools for content optimization, this distinction matters: some products diagnose the problem, while others are designed to produce the new content as well.
📊 Use competitor wins to decide what to improve next
Do not treat competitor visibility as a vanity metric. Use it to find gaps in your own website and wider presence.
Look for:
  • Prompts where competitors appear instead of you
  • Pages supporting their visibility
  • Topics they cover more completely
  • Sources that cite or mention them
  • Information missing from your own website
Beamtrace, HubSpot, Semrush, Writesonic, and Profound can all help connect competitive gaps with potential actions.
This is often more useful than trying to optimize every page equally. Focus first on the questions where competitor visibility overlaps with real customer intent.
🔗 Strengthen third-party authority when your website is not enough
Not every ChatGPT visibility problem can be solved by editing your own pages.
Review which external sources repeatedly influence answers in your market, including:
  • Review platforms
  • Comparison websites
  • Industry publications
  • Communities and Reddit
  • Business directories
  • Other independent sources
HubSpot and Writesonic make third-party opportunities particularly explicit, while Beamtrace can connect citation and source gaps with its wider Action Plan.
If competitors are consistently supported by sources your brand is missing from, off-page work may have more value than another round of on-page rewriting.
⚙️ Automate only after you know what deserves fixing
Automation becomes useful once the strategy is clear. If your team already knows which pages, topics, or content gaps need work but cannot execute quickly enough, Profound and Writesonic provide stronger content-production workflows. Scrunch can automate parts of the AI-agent experience for larger enterprise websites.
Generating more content before understanding the gap can simply create more pages without improving the signals that matter.
📈 Measure the same prompts after making changes
ChatGPT does not have a stable numbered SERP where a company permanently holds position #1. A brand might appear first for one question, lower for another, disappear from a third, or move when the answer is generated again.
That is why the best optimization tools for ranking in ChatGPT should also help you measure what happens after the changes.
Keep a consistent set of commercially relevant prompts and monitor:
  • Visibility
  • Brand mentions
  • Position
  • Competitor Share of Voice
  • Citations
  • Recommendation context
Look for sustained movement rather than one unusually good response.
Tip:
The best GEO tools for ChatGPT optimization are not necessarily the platforms with the most AI writing features. First determine whether your main problem is technical access, content clarity, competitive gaps, citations, or execution capacity, then choose the tool that addresses that specific weakness.
Which ChatGPT optimization tool should you choose?
For most website owners, the practical shortlist is smaller than seven products.
What you needStrong fit
Affordable website audit + prioritized fixesBeamtrace
Affordable multi-engine recommendationsHubSpot AEO
Low-cost technical/content GEO auditOtterly.AI
ChatGPT optimization alongside established SEOSemrush
Content creation + broader GEO executionWritesonic
Automated enterprise content optimizationProfound
Technical AI-agent optimizationScrunch
If you run a small or medium-sized website, start with the products that can identify a manageable number of real problems without creating another full-time marketing discipline.
More expensive systems become valuable when volume changes the problem – hundreds of pages, multiple markets, large content teams, complex technical infrastructure, or a dedicated AEO program.
